J.D. L overheats
Tom in Central
10-30-2006 18:06:51
Several years ago, my neighbor got an L, basket case. Now it"s together and running, but after 30 minutes running, it"s at 220 deg.F. Radiator flows water freely. Engine maybe not. Any ideas?
Could he have been given a LA head? Or some other wrong part?
AWB
10-31-2006 06:26:16
 Re: J.D. L overheats in reply to Tom in Central Pa, 10-30-2006 18:06:51
Are you using antifreeze in the tractor? If so, be sure that the antifreeze/water solution is thoroughly mixed before putting into tractor or it won't work properly in a convection type cooling system. Remove the radiator cap and check to see that the coolant level is high enough that you have the coolant being able to flow freely from the engine to the radiator. In other words the coolant level should be put so that the coolant level is at the overflow pipe level when the coolant is installed. If not, this is a very common cause of overheating in the L or LA John Deeres. Do not use tap water! Use distilled water to mix with antifreeze solution so as to prevent lime deposits from plugging up your cooling system. Hope this helps.
