830 Pup Smokes
JO CAN
10-30-2006 11:02:42
What are some of the reasons the pup on my JD "830" smokes and sometimes a wee bit of oil comes out of the exhaust? ( Is this normal for a wee bit of oil to come out?) I know it could be the piston rings. Could it be anything else as well? I have changed the diaphram on the gas oil pressure switch. What about the valve guides? Has anyone had to change them to correct this problem? Is it possible to still purchase valve guides and if so where? I would like to hear from someone who has had this problem and how they fixed it. Maybe just a set of rings will do the trick. The engine starts and runs very good. Will do a compression test later to day. Maybe I should just leave it alone, but I don't like it smoking like that. Thanks to anyone with some advice.
buickanddeere
10-30-2006 17:45:12
 Re: 830 Pup Smokes in reply to JO CAN, 10-30-2006 11:02:42
A miss firing plug will make them smoke. As previously stated changing the oil never hurt as it gets thinned out. I now use a straight grade synthetic and see much less smoke. A bunged up oil return hole under either rocker arm cover will do it. An over rich mixture will make smoking worse. If nothing else the smoke keeps the mosquitoes away.
Chuck730DSE
10-30-2006 13:33:38
JO CAN, I bought my first JD with pony starter 6 years ago and it smoked pretty badly. I was told by a number of the JD "experts" that they all smoke like that.
Finally I hooked up with a guy that knows better. I pulled mine down, had the liners honed, put new rings in, checked the guides while it was open.
I broke it in like you would any old engine. I ran it for short intervals and let it cool down, increasing the run time and speed on every run. You may see a slight bit of smoke when it first starts if it has sat for a time without running. I think that is caused by raw fuel from choking it.
The main thing that worn these out was, as mentioned, gas getting in the oil from various causes. Make sure you have good clean oil in it and change it every time you change the big engine, that is why it dumps in to the big engine.
JO CAN
10-30-2006 19:29:16
 Re: 830 Pup Smokes in reply to Chuck730DSE, 10-30-2006 13:33:38
Chuck, did you notice any play at all in your valve guides? I took mine apart tonight and saw a little play. Liners look good. I will replace the rings and hone the liners. Thanks Chuck
mjbrown
10-30-2006 11:20:17
I had a smokey pony on a 720D and it was gas contamination of the oil in the pony. I replaced the shut off valve which was leaking and the gas thinned oil and it reduced the smoke quite a bit . The carbs leak gas into the cylinders and it runs down into the pony sump and thins the oil. Shut down the pony by closeing the gas shut off valve and run the carb out of gas. Then remember to turn off the ignition to save your coils
