3020 hydraulic leak at remote coupling
Gary Cobb
10-30-2006 08:13:17
My 3020 has a slight leak at the two remote ports where you plug in hydraulic lines. Is there a repair lit available for this? I"m assuming it"s probably some sort of seal or O-ring fix. Thanks!
Bob
10-30-2006 08:32:17
 Re: 3020 hydraulic leak at remote coupling in reply to Gary Cobb, 10-30-2006 08:13:17
Have you replaced the "O" ring (quad ring) and backup ring that is visible inside the coupler body?
If so, and it still leaks, the seals between the coupler body and the barrels may need to be replaced. The kits are readily available at Deere, but it's a little tricky, as there is a little spring and circlip and some rather tiny "O" rings and seal rings involved. If you get to that point, post back, and someone will help with the details.
