4010 sterring
shallan
10-30-2006 07:08:17
I have read many posts about steering issues on 4010�s mine was doing the not steering to the right and wondering all over the road thing so I took the steering motor [the thing under the dash] out and had it rebuilt at a JD dealer [no small task and a lot of cash] now it is starting to do the same thing 1 � years latter. Can anything be done short of taking the steering motor out and having it rebuilt again?
Tx Jim
10-31-2006 04:07:12
 Re: 4010 sterring in reply to shallan, 10-30-2006 07:08:17
The o-rings in steering motor can be replaced without R&R steering motor. Carefully lift and secure front of tractor. Drop frt end and gear that it attaches to . Remove one side rail,remove plugs and pull both racks. O-rings are on each end of racks. Reinstall and "time" steering gear. Much easier in my opinion than R&R steerin motor. Tx Jim
HTR
10-30-2006 19:28:33
 Re: 4010 steering in reply to shallan, 10-30-2006 07:08:17
The steering valve is located under the dash. The steering motor is located in the front of the tractor.
Not always, but most of the time, the right turn problem is caused by bad Orings, on the pistons, in the steering motor. Left turn steering oil, from the main pump, is directed through the pressure valve, in the steering valve, to the steering pistons in the steering motor. As you are using pump flow to turn left, you don't run out of steering oil. Right turn uses a precise amount of oil trapped between the steering piston, in the steering motor, and the upper side of the steering piston, in the steering cylinder, located on the top side of the steering valve, under the dash. If the Orings in the steering motor are leaking, you loose some of your right turn trapped oil. Turning the steering wheel all the way to the right, and holding it there, opens the synchronizing valves and allows oil to fill the steering pistons, and the front wheels catch up. Also the upper oring in the steering cylinder can show the some symptoms, but not very often.
To check the Orings in the steering motor, remove the leak off line from the steering motor to the oil cooler. Cap the fitting on the cooler, turn the steering wheel and observe the amount of oil coming from the line. If you get more than a few drops a minute, the Orings or bad in the steering motor.
