47 John Deere B
Sol Redlin
10-30-2006 03:22:59
I have a 1947 B that sat for a couple of years. It ran fine before but now seems to not have enough compression to start. What should I look for first?
1951FarmallH
10-30-2006 16:16:26
 Re: 47 John Deere B in reply to Sol Redlin, 10-30-2006 03:22:59
I had the same trouble with my '43 JD A. After pulling the head off, i found that a valve was stuck open. Good luck finding the problem.
John T
10-30-2006 04:44:44
Sol, If its sat for a long time and all the oil is depleted from the rings n cylinder walls, it may help to squirt some oil into the cylinders via the plug holes and then try it maybe even pull start it until it gets an oil seal built up. It wouldnt hurt to install new plugs and check the points and if gray oxide coated non abrasively clean/buff/polish them and check the gap.
If you remove the plugs so you can crank it over slow see if it has compression on BOTH cylinders cuz if a valve is stuck open it wont have any plus you may be able to hear where compression is escaping like the carb if an intake vaslve or the exhaust pipe if an exhaust valve.
If pull straritng gets her to run but the compression is still low cuz the rings are stuck n not expanding n contracting I would change the oil n add some Rislone and auto tranny fluid with good high detergent oil and run her long n hot n hard to try n free up the rings then change back to regular oil, maybe add some Marvel Mystery Oil to the final mix.
John T
Gary from Muleshoe
10-30-2006 04:12:34
Could possibly be a valve stuck open, or collapsed rings.
