4020 injection pump governor?
Jason Z in MO
10-29-2006 19:54:39
I looked back in the archives and I think I have my answer but I can't find the exact symtoms in the old posts that my 4020 is showing.
I think the injection pump governor is coming apart. I have a DBGVC633 pump. Starts fine, I can idle from 600-800 RPM and up to 2000 or so. Sometimes when closing the throttle to shutdown it won't drop below 1500 or so. Opening and closing the throttle will eventually let it drop down and die.
This is a project tractor that I haven't ran under load so I can't tell you much more.
Does this sound like a rebuild in my future?
Is the Roosamaster model DB a good pump?
Thanks!
Jason
msb
10-29-2006 20:36:28
 Re: 4020 injection pump governor? in reply to Jason Z in MO, 10-29-2006 19:54:39
Remove the timing window and see if there is some finely ground up black looking plastic inside the window.If so, the pump needs rebuilt.Some people will tell you to just remove the return line fitting, but after a while the rivets on the governor weight retainer will wear off and I have seen that cause a lot more damage that what little extra life you would get out of the pump is worth.
It also possibly it could also be a sticking metering valve. The later valves were made from aluminum to cut down on the valves sticking so bad.Sometimes they can be cleaned up and sometimes they need to be replaced.You might try a can of diesel fuel additive.That might loosen the valve up if that is what is the problem, but I never had much luck using the additive. Open the window and have a look first before trying the additive.
The Roosa Master is a very reliable pump after the newer style governor weight retainer is installed.That does away with the plastic weight retainer seals that deteriorate ,break up and plug the pump.The only other wear point of any significance is the transfer pump in the top of the pump,but if you keep clean fuel in the tank , the transfer pump will go a long time before it needs rebuilt.
