JD 4020 -what's it worth?
Tom N MS
10-29-2006 17:19:39
Looked at one today that seems to be in outstanding condition. Don't know a lot about the 4020 but it is diesel. What would be a reasonable price range? Thanks
buickanddeere
10-30-2006 07:16:27
 Re: JD 4020 -what's it worth? in reply to Tom N MS, 10-29-2006 17:19:39
Before anyone purchases a 34+ year old tractor. They should at least price a 6603 at the deere dealership.
Gerald J.
10-30-2006 17:17:31
 Re: JD 4020 -what's it worth? in reply to buickanddeere, 10-30-2006 07:16:27
For the $40,000 tag on a 6603 I could buy four to six 4020 that will also have significantly more crop clearance than the 16 or 18" of the 6603 front axles (lower with the FWD axle) and each of those 4020s will appreciate in value so long as I don't destroy them. The 6603 won't live long enough to appreciate in value, nor will I. The increased fuel economy of the 6603 won't pay out even if its run 1000 hours a year.
Gerald J.
jd@antique acres
11-01-2006 15:46:26
 Re: JD 4020 -what's it worth? in reply to Gerald J., 10-30-2006 17:17:31
From what I have seen of the 03 series they are just a plain tractor that will never last as long as the 4020. 40+ years and counting
buickanddeere
10-30-2006 17:47:59
I'll still take the 6603 M4WD with improved fuel efficiency rather than 34+ years of wear, deteriation & trouble. What are you driving over to need near high crop ground clearance.
Gerald J.
10-30-2006 20:50:59
 Re: JD 4020 -what's it worth? in reply to buickanddeere, 10-30-2006 17:47:59
Used to be cultivating corn and beans, now its spraying them with glyphosate when they are about 30" tall. I've put 12.4-42 tires on the back of the 4020 to narrow them to fit in the rows better. Didn't change the axle height from 27" clearance from the 18.4-34. I have 11.00-16 on the fronts that also give the front axle 27" clearance. Far more than the 6603.
Gerald J.
buickanddeere
10-31-2006 08:07:08
 Re: JD 4020 -what's it worth? in reply to Gerald J., 10-30-2006 20:50:59
Most operators around here either have the factory built high clearance sprayers. Or they have the same company they purchase the spray from, custom apply the spray. I figured the cost and I can't purchase the concentrate and spray for less than the Farm Supply to spray. Plus I'm not breathing the stuff in or getting it absorbed though the skin.
jd@antique acres
11-01-2006 15:41:18
 Re: JD 4020 -what's it worth? in reply to buickanddeere, 10-31-2006 08:07:08
You can purchase the chemicals for cash cheaper per gallon/pound/ounce then the custom applicator charges running it through their equipment. Plus the job some of these custom guys do leaves a lot to be desired. They are most interested in acres done than doing a good job.
j cook (iowa)
10-29-2006 17:36:50
Some questions:
1.) What year?
2.) what chassis type? (Standard, Rowcrop, Industrial, High crop?)
3.) Does it have a cab?
4.) How many hours?
5.) When was it last overhauled?
6.) Wide front emd?
7.) What size and condition are the rear tires?
8.) How many remote hydraulic outlets?
9.) Does it have a complete functioning 3 point?
10.)What condition is the paint?
11.) What "extras" does it have---like duals?
12.) Does it start easily?
13.) 12v or 24v?
14.) where is it located for sale? (Dealer or private or auction)
Tom N MS
10-29-2006 17:56:36
 Re: JD 4020 -what's it worth? in reply to j cook (iowa), 10-29-2006 17:36:50
Most of your questions I am not sure about but has New tires, new paint, single hyd outlet. Don't know the hours or when last overhauled. Wide front end. No cab. Looks like a new one.12 volt, starts easy, no duals. Standard Chassis, 1974.
TIMAR
10-29-2006 17:22:19
Year? Tire condition? Single or dual hyds?
Tom N MS
10-29-2006 17:32:07
 Re: JD 4020 -what's it worth? in reply to TIMAR, 10-29-2006 17:22:19
1972, new tires, single hydr.
TIMAR
10-29-2006 18:33:46
 Re: JD 4020 -what's it worth? in reply to Tom N MS, 10-29-2006 17:32:07
In my area of KS, would be 9K-12K
Tom N MS
10-29-2006 18:57:43
 Re: JD 4020 -what's it worth? in reply to TIMAR, 10-29-2006 18:33:46
Thanks- that's more than I'm going to pay for one that age..
Nylon
10-30-2006 09:45:13
 Re: JD 4020 -what's it worth? in reply to Tom N MS, 10-29-2006 18:57:43
I have an 03 790 deere 4x4. I also have a 68 4020. I paid more for the 790 than the 4020. I keep wondering why. Don't discount the 4020. It had been a great tractor when we had it on the farm for 15 years in early 70s. That is why I went to find another one 2 years ago. This tractor works great for loader,wood, dirt work, road maint and plowing and such. Was our main tractor on grade b dairy 300 acres of silage alfalfa plowing oats and etc. Another tractorthat is almost as versitile as the 4020 but less hp and weight that I can recommend is a farmall 460. I like the gas version of that.
You can find a good 4020 ..they are out there in the 7-10k range. A good 460 runs 3-6k. 460s are in the 50 hp range. The 4020 is 95 hp...and the little 790 is 28hp.
