620 propane fuel system
old Hank
10-29-2006 09:04:05
I took my fuel strainer off to clean.
Did'nt find much crud.
What else should I check for since I have it
apart.
Glen in TX
10-29-2006 12:49:33
 Re: 620 propane fuel system in reply to old Hank, 10-29-2006 09:04:05
If it has been sitting a long time not running could be several things to check or none depending on condition. Check everything you can later with soap solution for leaks before filling tank full (80%). Water hose and fittings to vaporizer can get calcium build ups plugging them not allowing good flow to warm fuel in vaporizer on these old ones so check those out. Check the water drain fitting on vaporizer also.
Ben.So.Tex
10-29-2006 11:02:19
Were you have having problems with it?
