AB1545R 3 way fuel valve '39 A
green
10-28-2006 19:38:30
I have purchased a AB1545R repro. fuel valve for my '39 A and I am wondering if it is the correct valve for the application.
When I turn the selector rod to a position, which is identified by raised letters on the instrument panel, the valve will not operate the correct tank that coincides with the ID letters. I am thinking that the valve is incorrect.
Here is how my system is currently set up.
O= Small gas starting tank
G= Large Fuel tank
F= OFF
Thanks for any input�
Glen in TX
10-29-2006 12:43:36
 Re: AB1545R 3 way fuel valve '39 A in reply to green, 10-28-2006 19:38:30
Mike and Bob got you right on the positions and that's the right valve for your 39. Maybe you have wrong index stop or it's off 180� or backwards? There were 2 different index stops on late A and 3 different control rods according to parts catalog.
Bob Bedlan
10-28-2006 20:25:22
I think it should be O is off G is gas or small
tank and F is fuel or the big tank. Just my
thought.
James Howell
10-30-2006 13:42:52
 Re: AB1545R 3 way fuel valve '39 A in reply to Bob Bedlan, 10-28-2006 20:25:22
I agree with Bob.
I recently installed a NOS 3-way valve on the 43B.
The old valve was turned clockwise as far as it would turn. This bottom position was "O"ff.
The next counter-clockwise position was "G"as from the small tank.
The top counter-clockwise position was for the All "Fuel" large tank.
Hope this helps.
Mike M
10-29-2006 05:01:41
Bob; I agree with you on those settings.
