Getting Wheels Off
jd ag
10-28-2006 16:29:23
Just purchased a 1937 A JOHN DEERE it has flat spoke rims wheels are stuck on tight need to put new tires on any information would be helpful.
Paul from MI
10-30-2006 04:37:50
 Re: Getting Wheels Off in reply to jd ag, 10-28-2006 16:29:23
I use a homemade bead breaker. It's basically a large slide hammer with a piece of old truck leaf spring welded on for wedge to go between the bead & rim. The end of the spring needs to be ground smooth so you don't cut up the tire. Add weight as needed to get the right amount of force. I think I have about 15-20# on mine. Just kept welding on pieces of scrap iron to the hammer part till it worked. Once the bead is broken loose, it's a piece of cake with some spoons and rubber lubricant. I sometimes use straight antifreeze, as it doesn't corrode like soap. Good Luck,
Paul
machinery-man
10-29-2006 07:28:59
it would be interesting to know what type wheels you have. I had a 38 B that had the suicide rings and personally didn"t like to mess with them. Once on they seemed okay but I spot welded them anyway. Those wheels are easy to change tires and you don"t need to pull wheels off tractor. I always change tire on any tractor with the wheels on. With an old rubber hardened tire I"ve had to use a small grining wheel and cut the rib. My experience has been cleaning up the rims is the hard work.
CalJim
10-28-2006 21:49:25
Just how do you change tires that way?
Are you talking tire co. mobile unit
with power equipment? Or do it yourself
with some big tire spoons? Just curious. CalJim
Paul from MI
10-28-2006 18:38:12
If the only reason to remove the wheels is to change tires, don't do it. The tires are easier to change with the wheels on the tractor. You can use the weight of the tire to help you with removal and when installing the new ones.
If you feel compelled to remove the wheels for some other reason, use a lot of patience. The clamp ring is easier to remove with a little heat after soaking with penetrant for a couple of weeks. Whatever method of pulling you use, be sure all of the force is between the wheel or clamp ring, and the axle. Don't do anything that puts stress on the axle bearings or axle housing. Again, patience is a virtue.
Good Luck,
Paul
JD AG
10-29-2006 06:44:06
 Re: Getting Wheels Off in reply to Paul from MI, 10-28-2006 18:38:12
Thanks Paul I have seen truck tires changed that way so i guess the princple is the same.
