3010D won't run
Eddie Jones
10-28-2006 14:39:43
I have a 3010D that will start but but won't run long, maybe a 30 to 40 second. I have change both fuel filter have check fuel pump. Guess I need to check fuel injection pump. How would you go about checking it? Or could it be something else? Any sugestion would be a big help. Thanks Eddie
3010
10-29-2006 10:02:28
 Re: 3010D won't run in reply to Eddie Jones, 10-28-2006 14:39:43
if it cranks and runs it is probably either a plugged return line to the fuel tank or either the check ball in the return line elbow is stuck and not opening to let the excess fuel return to the fuel tank. if you are standing and facing the pump this elbow screws into the "cap" on the LH side of the pump. The line that attaches to it will go to the top of each injector and then continue to the fuel tank. Screw the fitting out and crank the tractor if it continues to run ok then the problem is in the fitting or line. Remove the check ball and spring out of the fitting and throw them away. This is a common repair because the check ball sticks and plugs the elbow causing pressure to build in the injection pump which causes the pump to stop pumping and the tractor cuts off. after fixing the elbow blow air through the return line until you hear it blowing out the fuel tank. reinstall all parts and that should fix your 3010. if you crank the tractor with the elbow fitting removed and it does not run then you have either an injection pump problem on a fuel supply problem and there are other things to check before removing the injection pump
hope this helps
Eddie Jones
10-30-2006 07:20:58
 Re: 3010D won't run in reply to 3010, 10-29-2006 10:02:28
I took the return line loose and it run. So it shouldn't be my fuel injection pump. It clear thru to the fuel tank. I put it back together and it still run 30 to 40 second before it die, take the line loose and it will run. Where would the check ball and spring be, is it inside the pump? Thank for all your help, Eddie
matthies
10-28-2006 18:56:30
Also pull off the fuel line before the lift pump to see if you have good fuel flow. Have seen some trash plug the outlet of the fuel tank and starve the engine. And if no fuel flow blow back with air gun to get blockage clear. chris
msb
10-28-2006 17:57:47
Remove the return line and fitting out of the injection pump.If it runs with the fitting out, the short and sweet of it is have the injection pump rebuilt.
msb
10-28-2006 17:57:32
