8650 overheating
Bob seND
10-27-2006 18:52:15
8650 heats to the top of the temp gauge within the first 30 minutes of operation. If the tractor is idled for 15 minutes the temp comes down and it can be worked all day long after that without getting over half way up on the gauge. This is consistent and changing out the thermostat made no difference.
any ideas?
Bob seND
10-28-2006 20:50:49
 Re: 8650 overheating in reply to Bob seND, 10-27-2006 18:52:15
Thanks Matt, I'll trace out the wiring for
loose connections and check the actual temp.
Bob seND
Matt871
10-27-2006 19:18:47
I've had a similar experience and it was a fault in the Investigator II system. Use an infrared thermometer to determine if the engine really is heating up. On my tractor, if I shut the key off when the gauge was pegged, then turned it back on, the system would reset and be fine for a while. I had other electrical problems, so I replaced all the wiring harnesses and sending units. In the process, I found a loose wire near the back of the head, which used to go to a head temperature sensor that was removed by service bulletin. When this wire contacted ground, the gauge would peg and the alarm and light came on. Hope this helps narrow your problem down.
Matt
