How does a temp gauge work??
EMG
10-27-2006 18:24:53
The "wire" on my coolant temp gauge on my 2010 broke and I would like to attempt to fix it but I'm not sure how it works. Does is work thru heat conduction or pressure or something else.
Thanks for any info!
EMG
10-28-2006 05:39:57
 Re: How does a temp gauge work?? in reply to EMG, 10-27-2006 18:24:53
I figured that would be the case- Thanks for the info!
Bob
10-28-2006 11:04:15
 Don't give up so easily.... in reply to EMG, 10-28-2006 05:39:57
Heat gauges CAN be repaired.
It'a probably NOT doing for your 2010, 'cause it can be replaced.
Check out the link below:
Roy Suomi
10-27-2006 19:45:34
The capillary tube style of temp gauge is not repairable. There is a tube with a liquid or sort of mercury inside that pressurizes with temp changes. This causes the needle to move inside the guage..You will need to change out the guage assembly.
EL:I
10-27-2006 19:43:51
Its a hollow tube that is filled with I believe ether. They are put together under pressure. There is no way to fix them.
