help id a john deere gas 6 engine
mike jenezon
10-27-2006 12:54:35
Hi this is a gas 6 cyl was on a spray rig ex on left if sitting in seat, physical size about like 300 ford 6 or maybe slightly larger any ideas . will get a pic and post asap. thanks mike
mike jenezon
10-27-2006 20:13:47
 Re: help id a john deere gas 6 engine in reply to mike jenezon, 10-27-2006 12:54:35
I found a model # on a tag on the block it says ba 248 dosnt sound like it is any of the tractor motors though . thanks mike
95CS
10-28-2006 06:14:49
 Re: help id a john deere gas 6 engine in reply to mike jenezon, 10-27-2006 20:13:47
The John Deere 248 6-cylinder was used in 95 and 105 combines, and in some cotton pickers. It was never used in a Deere tractor.
j cook (iowa)
10-27-2006 18:48:48
The JD built 6 cylinder GASOLINE TRACTOR engines that come to mind are:
1.) the 6302 engine found in the 4010.
2.) the 6340 and the 6360 GAS engines found in the 4020 (and 4000).
3.) the 6303 engine found in the GAS 4030 (Dubuque built)
There were also some other 6 cylinder engines, Hercules and Chevrolet which come to mind, that were used in OTHER SP equipment, ie Combines, Forage Harvesters, perhaps swathers...that sort of thing. I don't have the information on those, except that I am aware they existed.
Mike M
10-27-2006 18:14:57
A JD engine should have a casting number on the side of the block behind the starter. JD also used some Chevy 292 gas engines in some combines.
