24/12 volt changeover changed everything!
farmrgirl
10-27-2006 06:24:02
Solenoid after solenoid what is going wrong?
WTW
10-27-2006 06:50:14
 Re: 24/12 volt changeover changed everything! in reply to farmrgirl, 10-27-2006 06:24:02
If you are saying that the starter solenoids are failing or fail to function after a 24 to 12 volt conversion your problem is most likely due to not installing a starter relay ahead of starter solenoid. The existing key switch, neutral start switch and circuit wiring will not carry the required power to satisfy the current draw the 12 volt starter/solenoid. By putting a relay above starter to get more power to solenoid directly from starter cable will correct this problem. All the later 4020 and 3020 tractors with factory 12 volt system use this relay in this circuit. This is a place where allot of conversion kits fall short. That's why I build my conversions from scratch, good parts off the shelf. If you want to know how to wire it in just look at a electrical schematic for the later tractors. Get a starter relay for a 30 series tractor as they are the most common and easy to mount up. Pretty simple. Good chance there may be nothing wrong with the solenoids you are replacing. DW
farmrgirl
10-27-2006 10:33:19
 Re: 24/12 volt changeover changed everything! in reply to WTW, 10-27-2006 06:50:14
I already Have a relay installed just as you suggest. Can anyone tell me why the conversion starter does not have a serial plate?
Bob
10-27-2006 13:48:43
 Re: 24/12 volt changeover changed everything! in reply to farmrgirl, 10-27-2006 10:33:19
Rebuilt starters almost NEVER have the OEM model/serial plate, only a tag or stamping of the rebuilder's part number. The "belly" of the starter, where the original nameplate was MAY even be originally from a different application or voltage, and built up by the rebuilder for it's current application.
