1950 John Deere A clutch
jackie bieghler
10-26-2006 19:00:02
I've been posting questions on another site as it relates to my 1950 John Deere A clutch problems but with little response. I'm trying to replace an "operating bolt" that is one of 3 that hold the drive disc assembly, within the pulley wheel. It appears that I need to remove the pulley wheel itself to get to the back of it just to get to the old bolt. I've been told to remove the pulley brake assembly to slide off the pulley. I've removed the 4 bolts holding on the fork bearing, but it will not come off. It appears the fork shaft is holding it on. How can I remove the fork shaft from the fork bearing so that I can disengage it from the pulley wheel?
Mike M
10-26-2006 19:15:43
 Re: 1950 John Deere A clutch in reply to jackie bieghler, 10-26-2006 19:00:02
The fork shaft and bearing all come out as one unit. Pull them out to the front it may take some jiggling as the bronze fork fits in a groove in the operating sleeve and when putting it back in you must also be careful that it goes back into the groove.
