Clutch drive gear on US B
DEEREDAVE
10-26-2006 08:50:45
Ok this time I ask before I work. I am about to pull the drive gear from the clutch on a 35 brass tag B. I have fashioned a piece of 1/2 inch stock to bridge the opening and my question is, Should I apply some heat to the gear before I start pulling or go straight to the pulling process? Also it seems that the dogs are all rusted shut. Any tricks on cleaning and freeing these once I get the clutch apart.
BUDD
10-26-2006 15:43:09
 Re: Clutch drive gear on US B in reply to DEEREDAVE, 10-26-2006 08:50:45
DEEREDAVE I have done this a few times on my A (to slow down for pulling) I used a 3 jaw gear puller. I put a lot of pressure on the gear and then heated it up until it popped and then just pulled it off with the puller. To reinstall it I put the gear in a pan of water and brought it up to a boil for a while, I sprayed it with wD40 and beat it back on (went easy). Worked great for me!
BUDD
easydoesit
10-26-2006 12:49:17
A good article on clutches in Green Mag. last month.
DEEREDAVE
10-26-2006 13:46:01
 Re: Clutch drive gear on US B in reply to easydoesit, 10-26-2006 12:49:17
Yes I read that artical but if you notice he never tells you how to get that gear off. His words were "Now the fun starts" but no details. I grasp the concept just not the mechanics.
F-I-T
10-26-2006 11:25:56
On the dogs and toggles, a little subtle heat should free those. If it was me, I would put it in my electrolysis tank and de-rust it first.
Frank
Mike M
10-26-2006 10:27:35
Once you get that gear off you can take all the rest of the clutch apart and even sandblast it if really bad. You would have to really clean out the inside where the bushing and bearing go though.
The absolute best way I have found to remove those gears is with a hyd. gear puller. I'd see if you can rent one. If you do need heat wait until you get the puller pressure on it then apply the heat then it will pop when it is just right. When putting it back together you should need a press and make sure you support it on the inside hub area so as not to break the pulley rim. I heat the gear up away from the pulley hot enough to where spit sizzles good on it then quickly place it on the hub and press it all the way down,it may even fall on,but most need some help.
machinery-man
10-26-2006 11:08:12
 Re: Clutch drive gear on US B in reply to Mike M, 10-26-2006 10:27:35
Mike M. is on the mark. I did one of these on a 530 and took the item to my local dealer and used his hydraulic press. I doubt that a regular puller would exert enough pressure without possibility of damage. Also installed the new gear the same way. This is a pressed fit 0 tollernace or a shrink fit that holds the torque of the gear. Good luck.
Mike M
10-26-2006 11:56:25
 Re: Clutch drive gear on US B in reply to machinery-man, 10-26-2006 11:08:12
He must have a very large press to fit that thing in there and get something under the gear to hold it all. I have a pretty large 3 jaw gear puller that uses my hyd. port-a-power ram it hooks right on those gears and works great ! Works great to pull those live pto gears off the crankshaft too. I really like hyd. pullers. You don't have to fight the twisting forces and friction of the screw and once it pops you can really get it off fast with some quick pumps,sure beats wrenching on those fine threads of a puller. The first ones of these I did I borrowed a big OTC push puller. Took alot of set up time and a helper to hold everything then lots of HARD wrenching ! I hated to spend the money on my puller but it was worth every penny. They are so easy to pull those red. gears with I look forward to doing them now. If your around Ohio stop by and I'll pull it off.
DEEREDAVE
10-26-2006 12:16:10
 Re: Clutch drive gear on US B in reply to Mike M, 10-26-2006 11:56:25
Mike, as it turns out I am also in Ohio a little south of Columbus. I suppose it would be to much to ask that you and you puller are close to me.
Deardave
Mike M
10-26-2006 12:40:18
 Re: Clutch drive gear on US B in reply to DEEREDAVE, 10-26-2006 12:16:10
About 70 miles north of you near Ashland. email is open.
