620 misses at idle but barks true under load?
Kris
12-17-1999 19:58:07
My grandfather had a 620 that my neighbor ended up with that always missed or sounded like it was sputtering except under load when it ran fine.Last I knew it still ran like this.....any ideas?
Don
12-20-1999 09:31:32
 Re: 620 misses at idle but barks true under load? in reply to Kris, 12-17-1999 19:58:07
Check the throttle plates to be sure they are seating in the bore, back off the idle screw to be sure. if one is turned((cross ways to the bore)it will cause that cyl to get more fuel . Will it Idle on one cyl at a time? If so thats probably it ,if not you probably have a plugged Idle passage.
Bob
12-18-1999 22:32:23
Vacuum leak how does the intake manifold look any signs of cracks. could be the gasket too
Chuck
12-18-1999 03:11:06
idle passages stopped up
