8400 Starting Problems
Stuart
10-26-2006 07:47:59
I have a JD 8400 tractor that had a engine overhaul at 1338 hours because of a defect the factory wouldnt cover. When I rebuilt the motor I never never touched the injection pump but after getting it together it will sometimes throw a fault code saying the fuel delivery rack is out of adjustment. The tractor does not start well in the weather below 60 degrees. It started perfect no mater what temp befor the overhaul The dealership says that all they can do is have me take the pump to a local diesel injection shop and have it looked at. I asked the shop and they gave me the same line about bringing in the tractor or the pump. I think it could be an electrical problem since it is electric controlled. I have check on Servic Advisor and they give me a whole bunch of voltage checks to preform but still other people tell me there is a way to "home" the fuel deliver rack inside the pump and that the pump is not advancing at all when it tries to start. I need someone who is an expert at this to help me, sorry for the long post. Thank you very much for anything you can do.
Mark2 in OHio
10-26-2006 17:54:58
 Re: 8400 Starting Problems in reply to Stuart, 10-26-2006 07:47:59
Sounds like a very nice John Deere dealer. Just what Mr. Deere wanted his legacy to turn into.....what a shame.
Maybe Helpful
10-26-2006 11:07:57
First I'd find a trouble shooting Tech manual. It should tell you how to access codes and find voltages etc.This would be the least expensive. There are a lot of sensors to rule out. I'm not a JD tech but I've borrowed books and have fixed a lot of things from 55 series to 8400,10's 9550 to9760 STS. Good luck it will take some time, maybe it will be very simple,fuel temp sensor just a wild guess. OK everyone rake me over the coals.
El Toro
10-26-2006 11:34:51
 Re: 8400 Starting Problems in reply to Maybe Helpful, 10-26-2006 11:07:57
Hi Stu, Send an email to Ron Fink. He's a service tech for John Deere. [email protected]
Hal
Stuart
10-26-2006 11:18:08
thanks for the help. Is this pump dependent on temp sensor, coolant sensor or other sensors for parameters in advancing the pump for starting. can you tell me if there is a procedure for re-homing the fuel pump delivery rack inside the pump. I have heard that it requires a person to remove a plug in the front of the pump and then start the tractor.I have a bout 30 pages printed out from a service advisor program that deere has but it is no help.
