1940 JDeere A Choke
Fifth Wheel
10-26-2006 05:17:29
Just checking to make sure while facing the carb on my A, which direction is full choke and which is NO choke. Evidently I have started and left on choke. Now hard to start. Must have pumped the case full. Cranked a few times and had one heck of a boom. Scared the @%#$ out of me! No damage I don't think. I have several different tractors and sometimes forget exactly what to do on each one. Dumb, I know but theres the question. Thanks
Sam#3
10-26-2006 17:07:50
 Re: 1940 JDeere A Choke in reply to Fifth Wheel, 10-26-2006 05:17:29
Electric or manual Start?
If electric it will have a choke rod on the dash. The carb. lever will be looped and have a hole for the rod to attach over the top. Follow the action of the control. Pull the rod the plate turns clockwise.
On a manual start, which does not require a control on the dash, the choke lever will be short with no hole. It works opposite the electric start.
I noticed over the years that the two different configurations existed and wondered why. Long time ago (couple years) someone (Mr. Clooney, I think) on this forum explained it this way.
1945 A
10-26-2006 09:00:14
On my "45 "A", the choke is "on" when it"s pointing straight up, "off" when the lever is pointing at the radiator.
Duane Larson
10-26-2006 08:22:42
Fifth Wheel,
If you look carefully at the choke lever where the choke rod is attached, you should find a line which is stamped into the choke lever. That line is always parallel to the choke plate (unless somebody has reworked it or something). This is a useful note for all Deere chokes in general. So, just look for the stamped-in line when you walk up to any Deere to start it, and you'll know how to choke it.
Mike M
10-26-2006 05:56:29
Rusty Junk Tx seemed to explain it good back at the last thread ?
I guess at this point I'd take out the 2 bolts holding the air intake pipe on and pull it off and have a look at which way YOURS moves and even more importantly since it backfired that the choke plate didn't get bent up. It's even possible it came loose and fell out and is blocking it up all the time ?
