49 JD A Connecting Rod Bearings A-4659-R Standard?
green49jda
10-25-2006 19:21:27
I have to replace the badly worn connecting rod bearing inserts on my 1949 JOHN DEERE A. When I want to order online, I have to specify if my rod bearings are standard or what the size is. I don't have a parts book for the A, so can someone tell me if my rod bearings are standard or what the size is? Here is the part number that is on the bearing half: A-4659-R. I'd very much appreciate any help. Thanks.
El Toro
10-26-2006 07:03:13
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to green49jda, 10-25-2006 19:21:27
You need to take that crankshaft to your local auto machine shop and have it measured for wear
and for being egg-shaped. If it needs to be ground, the machine shop can supply the correct bearings.
We have a machine shop near us that reworks these JD engines for pulling. You can contact him at [email protected] if you need any questions answered. Hal
Glen in TX
10-25-2006 21:29:53
Yep, Invalid number you got there. Nothing even close to it for rod inserts in 60 parts catalog either which should be the same or close to main insert numbers either. For 60 the standard size rod inserts are AA5351R, AA5353R .002 under, AA5354R .004 under, AA6089R .020 under, and AA6090R .022 under. L@@K at the numbers again?
green49jda
10-25-2006 21:57:26
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to Glen in TX, 10-25-2006 21:29:53
I don't understand why the number could be invalid. I'll tell you everything it says on the bearing. Fm.004 U.S A-4659-R then below that part number it says 65. Does that help at all??? Otherwise, maybe I should take it to the Deere dealer??? Thanks.
Glen in TX
10-25-2006 23:25:01
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to green49jda, 10-25-2006 21:57:26
Like Bob said probably just the bearing half number and not like the set numbers I posted above for a 60. The FM.004 probably stands for Federal Mogul bearing, .004 undersize made for JD and then the bearing half number. Will need crank ground first to see what you need anyway.
Duane Larson
10-26-2006 08:16:40
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to Glen in TX, 10-25-2006 23:25:01
Glen,
I have a 1957 FM catalog which lists main bearings for the A but no rod bearings. I wonder if the 65 may be the date of the bearings. I'll look a bit more to see if I have a FM catalog closer to 65.
Glen in TX
10-26-2006 22:09:16
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to Duane Larson, 10-26-2006 08:16:40
Duane, Found I had one set of AF2228R bearings for 720,730 gas & LP in parts bin and both bearing halves are also marked with same number in ink F2181R and stamped FM 1 62. So maybe Jan. 1962? Box also marked (22702). JD 720/730 parts catalog shows them to be .004 under size but not stamped on bearings. All numbers now come up invalid at JD Parts too.
Bob
10-25-2006 22:05:57
O.K., I'll try this again.
The numbers on the bearing HALVES are a Deere "in-house" number for a BEARING HALF.
Since Deere doesn't sell the bearings by the "half", the part number for a PAIR of bearing halves (assembly?) is going to be different than the number on each 1/2.
You're not the only one who's seen that number, though. Punch up the link below.
I still don't understand what you are doing, though, if you are having the crank ground, or what you mean by "re-rounded"!
Duane Larson
10-25-2006 20:59:52
The part number A4659R is not in any A parts book, nor in the Master Parts Index.
Mike M
10-25-2006 19:43:19
You say badly worn ? You better get a mic and see how worn out of round and tapered that crank is.
green49jda
10-25-2006 19:48:35
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to Mike M, 10-25-2006 19:43:19
I'm not getting no mic. What I meant was that they have many scratches. I've already planned on getting the crankshaft re-rounded, but my question was ARE THEY STANDARD OR WHAT IS THE SIZE? Do you know that? 49 Jd A
Bob
10-25-2006 21:16:40
 Re: 49 JD A Connecting Rod Bearings A-4659-R Stand in reply to green49jda, 10-25-2006 19:48:35
The markings on your bearings are probably some "in-house" Deere code for 1/2 of a complete bearing, since it apparently does not show up in the parts lists.
If you are going to get your crankshaft "re-rounded" (ground, perhaps?) the size of the bearings you now have is MEANINGLESS.
After the machinist regrinds it, he will tell you what undersize to order the bearings in.
