JD integral power steering on a 50, which is pretty light in the front end, should turn the wheel(s) any time with one finger. They were darn nice units in their day, and still are today. On my 70D, narrow R-O-M front end, and a full load in the loader, you can turn the wheels back and forth and eventually auger them into a deep pit of a hole. Start out by finding out if the unit has sufficient fluid. It might work then, if it is not now. If you have to rebuild it, there are three main sections to pay attention to: pump, pedestal, and actuator valve assembly. You can test the pump output pressure to size up its performance. There is also a test for vane leakage that you can perform to determine if the pedestal needs rebuilt, along with the visual evaluation to determine if the unit has leaked its oil out the bottom, requiring a seal replacement. I would not operate it too long before determining if it can be made to be functional, because if it has been run without oil for some time, the pump could now be damaged.
