4020 LP spark plug
dwag
10-25-2006 06:11:42
What heat range spark plug is used on 4020LP gas? Dealer didn"t have in stock and were listed under JD# only.Local jobber gave me D14 Champions, tractor has D8 Champions in it. I GUESS the D8"s. Thanks.
dwag
10-25-2006 14:34:03
 Re: 4020 LP spark plug in reply to dwag, 10-25-2006 06:11:42
Thanks for your replies, I thought D14"s\C86 was too hot for LP but I"ll try them. Tractor was converted to "Ignitor" by local dealer with no success. Cust. changed back to points & cond but tractor will occasionally throw "fits". Last summer I replaced resistor wire in harness with a standard resistor which helped but didn"t cure problem. I will go out tomorrow and replace cap, rotor pts. cond,plugs, remove resistor and install 12v coil and see what happens.
Glen in TX
10-25-2006 21:04:25
 Re: 4020 LP spark plug in reply to dwag, 10-25-2006 14:34:03
Like Buick said earlier too about the spark plug wires run metallic core wires. If you got the carbon core resistor ones I'd get rid of them. I've always ran D14 or D16 in LP JD tractors and they work fine. Later spark plug catalogs say to use D21 but that is hotter than necessary and they just got LP and gasoline applications jumbled into one. The D9 plug runs well in MM 605 & 800 engines on natural gas.
Gerald J.
10-25-2006 17:18:57
My '68 gas 4020 uses a 6 volt coil and a resistor. The starter solenoid shorts out that resistor for better ignition while cranking. You may not want to take that out if there is an S terminal on your starter solenoid.
Gerald J.
Glen in TX
10-25-2006 11:35:52
dwag, It's a LP system you said and since the LPG fuel mixture should already be vaporized before reaching cylinder and plug a hotter plug is NOT needed like for gasoline engines. Too cool can cause fouling also. Champion D14 is the correct recommended plug in Champion catalog for all JD LPG tractors and has been for a long time. Anything like D8,D9,D12 is really too cold. The D14 is a tad colder plug than the D16 & D21 for gasoline engines. Others comparable to D14 would be a Denso M17 or AC C86. Hotter plugs can be run but not necessary with the vaporized fuel of a LPG or natural gas fuel system. Recommended spark plug gap is .015 for JD LP tractors and .015-.018 for any LP engine and .012-.020 for natural gas. The wide gap is not necessary to fire the LP vaporized fuel and opening the gap too much will cause sputtering and missing in a LP engine. The electronic ignition is a great thing to put on it but the wide plug gap is NOT necessary and may give you more fits and than help on a LP engine.
Gerald J.
10-25-2006 09:20:10
Something cold lasts a long time with LP. I'm thinking my gasoline 4020 came with D12 which I changed right away along with the carbon plug wires that would open intermittently. Made it buck in 8th gear.
Today I wouldn't put champion plugs in any engine I expected to run a while. They are intolerant of crud on the porcelain and don't clean up.
Gerald J.
buickanddeere
10-25-2006 07:48:37
3116 Autolites. Toss the resisitor core wires in the trash and get some solids made up or order some generic non resisitor wires from Summit Racing. Install a Pertonics points replacement unit too. Crank the plug gap out to 50 thou or more as long as the spark doesn't start to jump inside the cap. If you have been having some fouling or fuel hogging issues.Install a 195F stat as well, it will clean up and burn better. Check every inch of the air intake system. Mud/oil will plug pipes or the mesh if she's an old oil bath. Aircleaner lids get squashed and restrict airflow if cranked too tight. On a gasser.Don't believe the choke is open unless the hose is pulled from the carb and the blade looked at.
