1020 Gas
Farmer76
10-25-2006 04:28:48
I am going to look at a 1020 gas tonight. I was hoping someone could tell me what the major problems to look for would be. I will be honest I know nothing about Deere. So any help would really be appreciated. Thanks in advance.
Gwiz
10-25-2006 17:38:44
 Re: 1020 Gas in reply to Farmer76, 10-25-2006 04:28:48
I had a 1020 gas that would always overheat and vaporlock. Even after a new radiator and thermostat.
James
jdemaris
10-25-2006 06:30:01
The 1020 ag (300 industrial) is one of the best utility tractors that Deere ever sold. It does not have any bad engineering flaws - so the only thing to look for is general wear and/or abuse or neglect - like you would with any used equipment. And - even if it does have probems - it all depends on what you are paying for it. The last 1020 I bought - ran good but had bad paint, bald tires and a few wiring issues - and I paid $3200 for it - and it came with a pretty nice Alamo side-mower. The 138 gas engine, or 152 diesel, is the same engine as used in 350 crawler, 380 forklift, etc. Very common engine, parts are cheap, and it's easy to work on. For any Deere tractor - if it cranks over hard - especially when hot - it probably has some hydraulic problems. Sometimes a $5 manual pump-destroker is all you need. Also - the three-cylinder engine - if used with a front-end loader - will sometimes crack where the front-end bolts to the block. 1020s were available with several options - like two-stage clutch, or hydraulic independent PTO, ground-driven PTO, hydraulic Hi-Lo, etc. I've seen real nice 1020s and 300s sell for over $6000, but average condition tractors are often available in the $3500 - $5000 price-range. The 820s and 830s are just about the same tractors with different hydraulic systems.
machinery-man
10-25-2006 04:54:21
I"ve got a 1020 diesel and these are tough tractors. My opinion would be to check front end. It would be a plus if tractor never had a loader. Check the bolster and pins. You could do this by jacking up and seeing what type movement. Also check for blue smoke on engine after warm up. Also really check the 2 stage clutch. If this is bad, hundred of dollars needed. Also check transmission. If tractor was maintained you"re probably okay. If tractor has spin out wheels is a plus. Check rubber and steering for wear. Wish I could go with you. Generally you can eye a tractor and see if rough housed, marks on sheet metal. A lot of particular operators put a cow catcher(as I call it). To pack chains and prevent any brush, tree, damages. My opinion is not to jump in but ask a lot of questions. If seller reluctant to answer or coy with you, pass on item. Electrical is also a critical item, check alternator, battery. This is a $200-300 item. Good luck if I can help email me personally.
