Clutch on GP
Hector GP
10-25-2006 04:22:35
Any body have a answere to this question? I can not get the clutch to fully ingauge on my 1930 gp. I have adjusted the plates in and out but the fork must not be fully ingauging. It will run the tractor but if you don't hold the clutch lever it will stop. I don't get a full click when I push the lever forward.
DEEREDAVE
10-26-2006 09:07:34
 Re: Clutch on GP in reply to Hector GP, 10-25-2006 04:22:35
An article in this months Green Magizine should solve your problem. It covers the whole clutch and discribes the problem that you have.
Deeredave
Chooch
10-25-2006 16:05:10
Hector,
There are several factors that could be affecting your clutch operation. Here are some areas to check:
A) Adjust tension using 3 bolts on end of clutch. (sounds like you already tried this).
B) Check end play in crankshaft on flywheel side of the tractor. Excessive end play can affect the clutch operation.
C) Remove clutch cover and inspect clutch disks for wear.
D) Remove clutch drum from tractor and inspect the clutch dogs on the back of the drum for excessive grease build up and wear.
I had a tractor acting just as you have described. After checking A thru C above, I removed the clutch drum and found a lot of dirt and grease caked on and around the dogs. I cleaned everything up, put it back together and it adjusted great.
Dennis
Duane Larson
10-25-2006 20:40:40
 Re: Clutch on GP in reply to Chooch, 10-25-2006 16:05:10
Hector,
Adding to Dennis's nice list, if you end up pulling the pulley unit off, try rotating the operating sleeve - it should move only a very little bit relative to the pulley unit. There is a pin (the "drive pin") that holds the operating sleeve to the pulley unit, and if that pin becomes loose or worn it allows the operating sleeve to rotate relative to the pulley, and the clutch toggles won't stand up straight when going over center - one cause of poor snap when engaging the clutch. The only way to solve the problem is pull the drive gear on the end of the pulley and pull the operating sleeve off to repair the drive pin and/or hole in the operating sleeve in which the pin fits.
Hector GP
10-28-2006 08:43:32
 Re: Clutch on GP in reply to Duane Larson, 10-25-2006 20:40:40
One other thing the drive pin does not set up like in the picture in green magazine oct issue. It is even with the sleeve but is holding it.
Hector GP
10-28-2006 08:38:11
I took of the pully and it seems like the operating sleeve moves about a 1/8 inch at the most. Could that be a problem? Every thing else looks ok except the operating bolts are a little worn on the end kind of beveled?
Hector GP
10-26-2006 07:54:14
Thanks, sound like I need to pull it apart and check all these things. Thanks for all the information you fellows provided.
pensfan
10-25-2006 08:35:31
I had and old D john Deere that would do the same thing, finally found that the clutch dogs were wore out. Welded them up and seemed to fix the problem.
Hector GP
10-25-2006 17:31:21
 Re: Clutch on GP in reply to pensfan, 10-25-2006 08:35:31
Thanks for the replies. I will get into it deeper and see if one of these suggestions work. Thanks again
