JD 37 A
Mike D.
10-25-2006 00:42:37
What would make a 1937 unstyled A freeze up just sitting in a garage in just 3 months.
Tractor sat there for 2 years and it has been fine all this time and 3 months ago i tryed to start it and it would not start ,maybe the carb., but any way i was going to try it again 3 months latter, which was the other day and i could not even turn the fly wheel over,so i had to get a nother tractor to pull it and pop the hand clutch a couple times or so real lightly and it broke free. I dont understand how it would freeze so fast . any idea"s why this happened so it doesnt happen again. Thank"s
Jason Mills
10-25-2006 05:37:29
 Re: JD 37 A in reply to Mike D., 10-25-2006 00:42:37
Did you flood tractor when you attempted to start it? This could have washed oil off cylinder walls thereby making it easier for rust to form quickly. You didn't have a cylinder full of water or gas did you? If you did you may want to look at crankcase oil, that stuff will run by the rings in this amount of time. If you have weather like I have, there is always humidity helping rust to form quickly. This is especially true in a garage. I can sometimes walk in mine and have water on the floor and sweat dripping from my A. You could also pop off valve cover to ensure all moving parts are still moving and check to see if they are getting oiled. Could be a sticky valve. Check pushrods for straightness if you find a sticky valve, you may have one bent after pull starting because something had to give. Best of luck with your project, Jason.
