Choking my A
Fifth Wheel
10-24-2006 17:53:08
Have a hand start A and having trouble starting. This old A runs good but I have so many, I sometimes forget a little about a particular one. I just had it running and evidently left it on choke, it sooted up the ceiling and finally quit. I tried to start back but don't remember when facing the carb if all the way to the left or right is choking. My B has a hash mark to show, but the A doesn't, I know its probably a dumb question but there it is.
Jim Lockhart
10-24-2006 21:26:37
 Re: Choking my A in reply to Fifth Wheel, 10-24-2006 17:53:08
Mine is just the other way around choke lever to the right is choked and to the left is off choke.Or that is how I have been doing it and it has ran for a hour or better in the "left" off choke position.
Rusty Junk TX
10-24-2006 19:34:30
If it is a hand choke (no hole for choke rod from the dash or headlight arm), it needs to be in the UP or to the right to RUN. It needs to be DOWN (horizontal), or to the left to CHOKE or START. That is unless someone has jacked with it.
Marcus
Fifth Wheel
10-25-2006 05:33:10
 Re: Choking my A in reply to Rusty Junk TX, 10-24-2006 19:34:30
Thats probably what I have done, after it started I pushed all the way to the left while facing it. After it quit running, I cranked for a while and it evidently exploded what gas was in the case. Scared the *%#@ out of me. I just was not able to get it started again so I thought I would get some pointers again. Let me know what you think. Thanks Jeff
