3020 gas syncro No reverse
RJBouman
10-24-2006 14:40:39
My early model 3020 was hard to shift out of reverse for awhile. I put in a new clutch and bearings and still had problems. Then it shifted fine for a few days and then it lost both reverse speeds. Pulled the inspection cover under the platform and all the gears are there and no missing teeth. The syncro clutch chatters like crazy when I try to go in reverse. Is this just a syncro clutch issue? The top tranmission shaft seems to have a 1/4 inch of play front to back. Is that OK? I read most of the tanny messages and it seems the syncro clutch could be the problem. Any help would be appreciated. Thanks-RJB
msb
10-24-2006 20:31:47
 Re: 3020 gas syncro No reverse in reply to RJBouman, 10-24-2006 14:40:39
Linkage is probably out of adjustment.Adjust the linkage so the shift lever is centered in each of the shift stations (slots in shift quadrant) Jiggle the shift lever to be sure the detents engage the shifter arm before you adjust the length of the shift rod.
