49 b with no power
don cassese
10-23-2006 15:51:56
long time since I have been here. But my 49 b is running after a while. I notice that I can't shut the choke or she shuts down, and that when in 2nd gear, seems like very little power, like just enuff to keep the wheels turning. will shut down but will fire right back up. I recently changed the oil, but I haven't changed the plugs. It would be great to know what size/model and when I went to change a few months ago, I couldn't get a socket down onto them. Any ideas? I appreciate all answers, thanks all.
johndeereman
10-23-2006 16:18:57
 Re: 49 b with no power in reply to don cassese, 10-23-2006 15:51:56
i use autolite 3116 in my b you have to use a 7/8 wrench to get the plugs out sounds like a carb prob to me though how long did it sit might be parly clogged fuel line or the gasket from the carb to manifold might be bad so its suckin in air i would just rebuild the carb only cost abou 15 to 20 bucks then you could eliminate that.
B-maniac
10-23-2006 17:19:28
 Re: 49 b with no power in reply to johndeereman, 10-23-2006 16:18:57
Make sure the gas is FRESH and no water in it! May sound simple,but there have been people rebuild their carb and then post on here for help cause it didn't run any better,only to find out their gas was junk and had water in it also. Just something easy to check before you get all excited about rebuilding stuff!
Glen in TX
10-23-2006 21:54:23
 Re: 49 b with no power in reply to B-maniac, 10-23-2006 17:19:28
Try it with the intake loose too and see if it runs better and if so be sure air cleaner isn't plugged up with grease and dirt. Those ornery mud daubers like to help plug them too.
B-maniac
10-24-2006 08:00:47
 Re: 49 b with no power in reply to Glen in TX, 10-23-2006 21:54:23
One more note,if it were plugs and they were that bad,it wouldn't just start back up like you say. Plugs affect starting more than running. Also,choke position won't help a bad plug.
