Coolant for a 4020 Diesel
Tims4020
10-23-2006 10:57:50
Someone set me straight on what type of antifreeze to run in my 4020 Diesel. Should I run JD brand hygaurd coolant and mix with distilled water? Or can I run Prestone standard antifreeze mix? What about a coolant conditioner? IF so, should that be JD or can I pick a can up at NAPA?
Thanks,
Tim.
G/MAN
10-23-2006 13:40:52
 Re: Coolant for a 4020 Diesel in reply to Tims4020, 10-23-2006 10:57:50
The John Deere Cool-Gard is a 50/50 premix, and is a good product - 5 year/5000-hour coolant - so if cooling system maintenance isn't a major priority, I'd recommend that. Any good quality ethylene-glycol antifreeze mixed with good soft or distilled water will also work well, but the coolant additive packages (the stuff that protects the cylinder liners from cavitation, pitting and eventually pinholes leaking coolant into the engine oil) in an off the shelf automotive coolant isn't going to last nearly as long, so you'll likely find yourself replacing it every couple of years. The Cool-Gard isn't cheap, but it's convenient, you don't have to worry about the purity of the water, and you'll be good to go for several years.
Glen in TX
10-23-2006 13:24:18
It doesn't matter what brand but does matter getting the mix right for low temps in your area. If you run the JD antifreeze run what is compatible for conditioners with it. We always ran the co-op antifreeze or later the Prestone and ran the JD conditioners with both with no problems. Most conditioners are made to be compatible with all antifreezes now anyway and Prestone has several anti-rust conditioners also.
Tims4020
10-23-2006 13:52:02
 Re: Coolant for a 4020 Diesel in reply to Glen in TX, 10-23-2006 13:24:18
Thanks for the reply. I guess I am asking about the use of conditioner as well? This is my first diesel and am not familiar with using a conditioner, just read some post on here about it. This tractor will see probably less than 50-75 hrs a year. I would prefer to run a Prestone or Zerex over JD's brand, just for convenience and wanted to make sure that was ok. If I run Prestone, is the conditioner still needed for my 4020?
Gerald J.
10-23-2006 14:52:33
 Re: Coolant for a 4020 Diesel in reply to Tims4020, 10-23-2006 13:52:02
Diesel coolant conditioner is used to prevent cavitation on the outsides of the cylinder liners that would otherwise eat holes in them. Not every engine needs but it saves most wet sleeved diesel engines from premature failures.
Gerald J.
G/MAN
10-26-2006 07:43:28
 Re: Coolant for a 4020 Diesel in reply to Gerald J., 10-23-2006 14:52:33
There's more to the coolant conditioner than simple cavitation protection - corrosion inhibitors, anti-foam additives, etc. But yes, pitted-through liners are the most expensive problem poor coolant can cause. Some brands and models of wet-sleeved engine are more prone to cavitation, for some reason or other. IH engines for example. I've only seem one or two Deere engines with pitted-through liners, even when draining out coolant that looked like pond water, while it seems to be fairly common with IH 400-series engines - to the point that IH started putting coolant conditioner filters on their tractors at the factory. Could be the higher engine speeds they run and more liner vibration, as that's what really causes the pitting - the liners vibrating and bubbles imploding against the od of the liner wearing material away.
