730D Attachments looking for Info
MattG
10-23-2006 09:30:44
Hello All,
I have a 730D and am looking for info on attachments. What loader is compatible with my tractor? I have a WFE on it is there an original one I should look for, or an after market that will work? I would prefer not to have one that is a trip bucket, but can I put a splitter in so I can have dual hydraulics? I have a single output on the back right now.
Did John Deere make cultivators that would bolt onto this tractor like the Early Letter series? If so, where should I look to find a set of these?
So far I really like my new 730 Diesel.
Thanks.
Matt
pjcarlson
10-24-2006 11:43:58
 Re: 730D Attachments looking for Info in reply to MattG, 10-23-2006 09:30:44
Hi,
I have a wide front 720 with a Dual model 20 loader. It�s not Deere, its orange, but it works well on my tractor. This loader has down pressure. I use a PTO pump to drive the hydraulics. It connects to the tractor at 3 points on each side, rear axel, mid frame right below the engine block and front frame just below the radiator.
Take care,
Peter
Kevin L.
10-24-2006 08:19:57
Is he not going to have problems trying to drive into the quic-tach cultivators with the wide front end and it would take a lot of patience to go with the bolt on, especially a four row.. and hope I over looked the part that said three point mounted...
F-I-T
10-24-2006 13:14:08
 Re: 730D Attachments looking for Info in reply to Kevin L., 10-24-2006 08:19:57
He asked about cultivators, so I told him. Some people swapped the WFE with a R-O-M to install cults. Put the WFE back on later. Same for a mounted picker.
F-I-T
10-23-2006 11:58:26
For a WFE 730, the loader of the day from Deere would have been the 45W, which was available in trip bucket or hydraulic bucket. I have the hyrdaulic bucket model of the 45W for my 70D and it is a decent loader, and a good match for that size tractor. Some of the after market loaders mounted forward on the front cast frame rather than on the axle housing so they carry their weight on the front half of the tractor. If you want a Deere loader, you'd want to look for the 45W, or 45 for a narrow front end. As to how to feed it, there are some alternatives. One of the simplest methods if you want to break the lines is to install "Tees" which will let you feed the loader live and the Powr-trol system can then run in its own. If you don't want to split anything, your options will be limited if you only have one remote outlet.
The cultivators from many of the two-cylinders will fit your 730. We used a set of front mount 4 rows, with the quik-tach brackets on the 70. They sold thousands of those, so and unless they have all been sent to the junk yard, there should still be a few around. A 6 row set was also available for the 730.
Frank
