730 diesel turn up?
red fever 1206
10-22-2006 18:19:32
Hey guys I got a question that I hope you guys can help me with. I need to know how I turn up the fuel on a 730 diesel electric start? Also how far can be turned up and still be safe from harm? Friend of mine wants a little more power it seems alittle weak. Im an IH mechanic and dont get to work on green tractors much. Thank you for any help you can give to me.
Geoff Mathews
10-25-2006 05:26:19
 Re: 730 diesel turn up? in reply to red fever 1206, 10-22-2006 18:19:32
I have posed similar questions here a few times and oftem got silly answers such as the harder you push it the more likey it is to break. I expect we both know that, and that is why we ask the question. A few years ago in different circumstances I was told not to push it beyond 75 hp.
Geoff Mathews
10-24-2006 01:01:32
About 15 years ago I was given a set of propane injection equipment which I installed on my 730 - it is still there - it is ideal for lugging through a tough spot.
Dale in IN
10-23-2006 06:39:31
As buick and deere said check the air intake. I bought a 730D about 4 years ago and it was not hard to pull it down and kill it the first year I used it. I found the air cleaner about 3/4 plugged with sludge. It took 3 to 4 days to get it washed out and cleaned. It sure made a difference in performance. We had it on the dino in July of this year and it dinoed 61 HP. Had it on a 3-16 semi mount plow last week end and in the good black ground it just played with that plow. However when we hit the heavy clay ground it sure did a lot of barking and some raring. I was running 8" to 9" deep.This field had not been plowed since 1988.
Carl NY
10-23-2006 02:51:03
Before you get messing around with the fuel rack to supply more fuel, please consider these tractors have significant age on them and if you think the tractor is weak, chances are it has some internal wear issues that need addressed, like rings,valves,pistons & or injectors. Simply giving it more fuel isn't the answer.
Mike M
10-23-2006 05:44:46
 Re: 730 diesel turn up? in reply to Carl NY, 10-23-2006 02:51:03
VERY WELL SAID !
buickanddeere
10-23-2006 06:11:43
 Re: 730 diesel turn up? in reply to Mike M, 10-23-2006 05:44:46
Before pushing harder how about looking for restrictions?
Is a little weak a seat of the pants dyno reading? What does she make on an actual dyno? Replace the fuel filters. Clean the entire intake system from the intake snorkel and into the air cleaner mesh it's self. Check the valve lash. Get some new copper washers for the injectors. Remove the injectors and re-connect with them spraying away from the engine. Roll her over with the fuel on.A dud injector(s) will be obvious. Occassionaly a muffler will partly plug with a rusty baffle. Is the engine making 1250rpm fat idle and holding 1125+ at full load? A worn throttle linkage will make an otherwise sound tractor into a dog. The low pressure fuel transfer pump is 50+ years old. If it isn't making 50+ psi the engine won't make power either.
GPULLER
10-23-2006 09:58:24
 Re: 730 diesel turn up? in reply to buickanddeere, 10-23-2006 06:11:43
Fuel transfer pump should be between 12-24PSI, not 50+.
buickanddeere
10-23-2006 10:10:54
 Re: 730 diesel turn up? in reply to GPULLER, 10-23-2006 09:58:24
Th3 late 720's and 730's with the anti-reverse peanut cam run higher fuel pressure. 12-24psi is fine on prior machines.
coastiejim
10-24-2006 17:09:46
 Re: 730 diesel turn up? in reply to buickanddeere, 10-23-2006 10:10:54
I've never heard of the peanut cam. How do you tell if you have this type pf cam. Thanks!
buickanddeere
10-25-2006 07:55:49
 Re: 730 diesel turn up? in reply to coastiejim, 10-24-2006 17:09:46
Different part number on the cam and different lobe shape.Tranfer pump pressure control and pipe work is a little different too. I had an oil bath/shower from a backwards running green dash 720 at a tractor pull in front of the red, orange and other green coloured tractors. Not recomended.
