Computer lesson!
Loren NC
10-22-2006 05:46:13
I have noticed that several posts needed to use a temperature degree symbol (�) but did not. Apparently there is not common knowledge of how easily that can be done from any keyboard. The only important element here is that you must use your numeric keypad, NOT the numbers above the letters on your keyboard. Here is the way you do it: Hold down your ALT key then, ON YOUR NUMERIC KEYPAD, key 0 1 7 6, then release the ALT key. Try it! You will like it! There are MANY other symbols that can be accessed in a similar fashion.
James Howell
10-25-2006 11:51:36
 Re: Computer lesson! in reply to Loren NC, 10-22-2006 05:46:13
You can also Copy and Paste a typed degree � symbol. 1. Select/highlight the typed � symbol.
2. Right click and select/choose the COPY option.
3. Click to position your insertion point.
4. Right click and select/choose the PASTE option.
The � symbol will appear.
Jim Benson
10-23-2006 07:16:08
It's from the character map, found under programs/accessories/system tools. All kinds of stuff in there. �, �, �, �, stuff like that.
Glen in TX
10-22-2006 12:39:05
Ok so the Wico XH-1042 magneto with a 6274 drive cup set correctly should produce 25� lag angle. It works.
farmallman
10-22-2006 11:05:16
here is a website with a lot of different alt symbols (as they are called)
http://www.mesweet.net/altkeysymbols.html
Mike M
10-22-2006 06:21:00
let's try it out. 32� cool !!! now if I can only remember this.
Is there somewhere I can go to find a list of these ?
Harry Selleck
10-22-2006 05:57:58
ALT 248 will get the same results. In Microsoft Word "Insert" pull done menu will have "symbols" It has just about anything you want.
CPeter
10-22-2006 06:26:18
 Re: Computer lesson! in reply to Harry Selleck, 10-22-2006 05:57:58
Alt 167 also works. It was 30� here this morning.
CPeter
