2640 john deere
wkk427
10-21-2006 20:49:46
my pto does not work and power lift is very sluggish but when i pull the handle up to throw pto in gear the lift works like it should any ideas what is wrong with pto
Tx Jim
10-22-2006 04:15:58
 Re: 2640 john deere in reply to wkk427, 10-21-2006 20:49:46
I presume you have independent pto on your tractor. Probably pto brake line is cracked or broken. Could also be faulty pto brake o-ring, line o-ring or pto control valve. Independent pto's on 2640's operate from tranns. pump therefore leaking ones rob main hyd. pump. Tx Jim
