1940 john deere B- loose flywheel
maplehillfrm,pat
10-21-2006 18:39:22
hello guys I have this john deere B, I only start it once in a while, actually this is only the second time this year, I ran it around for a little while this afternoon, on steel sure is rough,
third party image
anyway, I see that the handcrank flywheel has about 1 1/2" - play side to side, is there a way to tighten this up? I see bracket behind it with 2 jam nuts do I just loosen them and "slide" it back on/ is there supposed to be any play or right against the housing, thanks pat
greenmech
10-21-2006 22:24:09
 Re: 1940 john deere B- loose flywheel in reply to maplehillfrm,pat, 10-21-2006 18:39:22
The two nuts on the inside of the flywheel are the ones to loosen and adjust your end play.5-10 thousandths of an inch is what the end play should be. Get the bolts good and tight and don't run it till you get all the play out. Ron Mn.
