I'm not quite sure WHAT you are doing, however, the transmission pump pumps oil forward to the cooler, along with any function return oil, and ALL this oil that is NOT used by the front pump returns to the rear of the tractor, entering the tranny's LUBE circuit. So, here's the deal... ...Big flow demand on front pump = MOST of the charge oil flowing through the cooler is used by the front pump, not so much returned to lube. ...Little flow demand on the front pump = nearly ALL of the charge oil flowing through the cooler MUST return to the rear sump, through the lube circuit. So, it works the OPPOSITE of what you are thinking. The only time the oil cooler relief valve will normally bypass is when the oil is cold and thick, and can't get through the cooler fast enough Do yourself and the tractor a favor, and get a GENUINE Deere service manual, and study and understand the color-coded hydraulic circuit flow diagrams before making any more uninformed attempts to injure the tractor (or yourself)!
