JD 60 throttle limit
Dairy Farmer
10-20-2006 13:43:12
I ahve a JD 60 runs good and everything BUT I want the tractor to have more throttle when i push the throttle lever farward. My neighbor"s 60 has about twice the rpms mine has at full throttle. Right now full throttle is where the lever is just a little farther forward than streight up and down. Not too fermilar with the oler JD"s because Only have the newer ones. any suggestions? T.I.A. DF
Mike M
10-21-2006 19:38:58
 Re: JD 60 throttle limit in reply to Dairy Farmer, 10-20-2006 13:43:12
You should see a bolt and jamb nut on the bottom of the throttle lever up under the hood,it sticks out the bottom a little. This is the high speed limit.
buickanddeere
10-21-2006 07:59:27
The rpm adjustments are all in your operator's manual.1-800-522-7448. If you are not using an accurate tach then nobody knows what the rpms really are. I have used three different colours of tape and a flourescent light to find 1200rpm in a pinch.
Dairy Farmer
10-20-2006 18:29:45
well yeah the govenoris workin. If it wasn't i'd say it in the message
JD Bobby
10-20-2006 18:37:06
 Re: JD 60 throttle limit in reply to Dairy Farmer, 10-20-2006 18:29:45
Well rocket man if it works how is it your buddy's runs twice as fast? DID YOU CHECK THE RPM's WITH A TACH?
Dairy Farmer
10-20-2006 18:48:07
 Re: JD 60 throttle limit in reply to JD Bobby, 10-20-2006 18:37:06
Well let's see here, the linkage and stop is MOST LIKELY SET DIFFERENT! I'm askin how to get more RPM's out of my 60. it's runnin slower than any 2cyl i have at full throttle! I'M JUST WONDERING HOW TO SET IT DIFFERENT!!
JD Bobby
10-20-2006 19:17:57
 Re: JD 60 throttle limit in reply to Dairy Farmer, 10-20-2006 18:48:07
Hook a piece of baling wire to the throttle shaft,don't worry about RPM's .It will be 4 times faster than your buddies.Hint you answered yourself fiddle with the linkage wide open throttle linkage at carb.half hole short,starting point,again tach it.
Dairy Farmer
10-20-2006 19:59:17
 Re: JD 60 throttle limit in reply to JD Bobby, 10-20-2006 19:17:57
thanks
CLW
10-20-2006 18:28:21
I think the rated (under load) RPM on the 60 is 975. That would make fast idle around 1150. Don't think it would be a good idea to run much above that. His may be running to fast. As far as where the throttle is set, that is about where most are. However it can be changed with adjustment to the linkage without changing RPM. If you don't have a tack. you can check your speed of your tractor in 6th. gear and it should be 11 MPH if you are around proper RPM.
Dairy Farmer
10-20-2006 18:34:46
 Re: JD 60 throttle limit in reply to CLW, 10-20-2006 18:28:21
well isn't there a stop on the throttle lever to keep it from going too far back ? can't you adjust it? No right now idle is probly around 450-550. and my neighbors idles at about 350-400r'sand full throttle on his is around 1150 and mine is probly around 850-950. I have a 70 diesel and full throttle on that is 1200so i was just thinkin full throttle was a little slow on the 60. Thanks everyone. DF
CLW
10-20-2006 19:44:27
 Re: JD 60 throttle limit in reply to Dairy Farmer, 10-20-2006 18:34:46
I think the stop is located under the hood at the bottom just about where the right light bar screws in to the side of the dash. My 630 slow idle is 600 RPM by the book. 500 may be OK but I sure would watch my oil pressure below that. They sound good at 300 but I don't know how good that is on the engine.
JD Bobby
10-20-2006 18:27:06
Have you checked the rpm's is the governor working, probably not.
