JD 4020 Oil Pressure
Dschaef
10-20-2006 06:40:39
When starting my JD 4020 it has 100# oil pressure, once it runs and gets to normal operating temperture of couse it comes down. While running at 1800RPM it will have 40# oil pressure, when I idle down to 7-800RPM it drops to 15#. My question is, is 15# oil pressure too low? Does this indicate any other possible problems?
dwag
10-20-2006 18:20:45
 Re: JD 4020 Oil Pressure in reply to Dschaef, 10-20-2006 06:40:39
Had one with erratic oil press and found bushing in oil press relief valve was loose in housing.
STEVE IN PA
10-20-2006 10:55:35
THE OIL PRESSURE SHOULD BE AROUND 30 AT IDLE AND 60 AT 2000 RPMS. I AGREE WITH GLEN FROM TX WHEN I BOUGHT MY 4020 WITH A REBUILT MOTOR SOMEONE PUT THE WRONG SIZE MAIN BEARINGS IN IT AND THATS EXACTLY WHAT MINE DID. HIGH WHEN COLD THEN ONCE WARMED UP HARDLY ANYTHING. I WOULD SAY CHECK THE BEARINGS OUT BEFORE SOMETHING MAJOR HAPPENS YOU MIGHT HAVE ONE SPUN.
msb
10-20-2006 08:24:59
I would check the oil for water or antifreeze contamination immediately.
Glen in TX
10-20-2006 07:08:42
How many hours? Any knocking? It may be wise to pull the pan and look for a spun rod or main bearing before you have something worse go wrong. Blockage of crank galley hole with spun bearing makes the pressure go up when cold or higher idle and then when things warm and bearing expands pressure stabilizes but yet drops low when at a idle.
dschaef
10-22-2006 05:11:37
 Re: JD 4020 Oil Pressure in reply to Glen in TX, 10-20-2006 07:08:42
Not sure on the tractor hours, the hour meter reads 500, but it was changed. Tractor does not knock, it smokes a little, plenty horse power. How hard is it to replace the rod and main bearings, can I do this by just dropping the pan and rolling the bearings in place?
Glen in TX
10-22-2006 12:22:46
 Re: JD 4020 Oil Pressure in reply to dschaef, 10-22-2006 05:11:37
You can roll bearings in but I'd check for water in oil or oil in water like msb said too and that may tell you if you need more than just bearings. Pull the pan and pull some bearing to see and you might find worse or not.
dschaef
10-23-2006 04:37:38
 Re: JD 4020 Oil Pressure in reply to Glen in TX, 10-22-2006 12:22:46
No water in oil, I turned in on the screw 1/4 turn and oil pressure jumped from 15 to 30 idling, @ 1800 RPM it is 55. I left it, Will this be okay or do you think I should go ahead and drop pan and inspect bearings. I have seen you give alot of good advice, I have used it on more than one occasion.
Thanks
Glen in TX
10-23-2006 06:59:06
 Re: JD 4020 Oil Pressure in reply to dschaef, 10-23-2006 04:37:38
If it holds and doesn't fluctuate up and down too much again it may be fine but if wide range swings of pressure still you have a spun bearing.
