720/730 head on a 70?
BDM
10-19-2006 19:31:41
Hello all. Can a late model head p/n F2701R be used on a 70 series engine? If so any parts changes I will need like valve cover, etc. etc? Thanks.
Brian
430WLPG
10-20-2006 20:16:57
 Re: 720/730 head on a 70? in reply to BDM, 10-19-2006 19:31:41
If it's gas they will NOT interchange, Cause one thing is the spark plugs are in the block on a 70 and they are in the head on the 720-730
BDM
10-20-2006 22:52:03
 Re: 720/730 head on a 70? in reply to 430WLPG, 10-20-2006 20:16:57
Thanks. Guess I would be looking at a block change also.
buickanddeere
10-20-2006 08:15:56
Yes. What are you doing about injector spray pattern & piston bowl shape? 1-800-522-7448 will get you the parts and service manuals required. All the interchange/upgrade parts are listed.
BDM
10-20-2006 15:17:07
 Re: 720/730 head on a 70? in reply to buickanddeere, 10-20-2006 08:15:56
Thanks for the info. I should have added it's a gas engine. Unless that p/n correlates to a diesel?
buickanddeere
10-21-2006 08:10:59
 Re: 720/730 head on a 70? in reply to BDM, 10-20-2006 15:17:07
It's a no. The 70 head is pretty decent anyways with a good three angle valve job, valve bowl blending and manifold to port matching. A fly cutter can be used to mill 1/8 to 3/16 of the eye brow away from the intake valve for more airflow. The head can be milled 125 no problem for more compression.
BDM
10-21-2006 09:04:43
 Re: 720/730 head on a 70? in reply to buickanddeere, 10-21-2006 08:10:59
Really? Well thanks for that info buickanddeere. Someone else mentioned it probably wouldn't be worth my effort to change over to the later engine design unless I'm trying to squeeze every last HP out. Thanks again.
buickanddeere
10-21-2006 16:16:52
 Re: 720/730 head on a 70? in reply to BDM, 10-21-2006 09:04:43
The blueprinting I was talking about is done on a stock 70 head to go on a 70 tractor. Cramming a 720/730 head onto a 70 is beyond practicality.
BDM
10-21-2006 16:30:01
 Re: 720/730 head on a 70? in reply to buickanddeere, 10-21-2006 16:16:52
Yes, I knew what you meant. Someone else sent me a message not to bother for practicality, as you say.
