820 clutch probem
hahter
10-19-2006 18:55:15
I have a 56 820 and the clutch has developed a clanking sound when I engage the clutch. The clutch was competely rebuilt by a JD service department before I bought the tractor. Could the problem be one of the sliding clutch drives or a bonded clutch disk that has seperated.
Any help would be appreciated.
Terry
hahter
10-22-2006 18:17:41
 Re: 820 clutch probem in reply to hahter, 10-19-2006 18:55:15
Thank you Frank. I will tear into the clutch next weekend and look at all the clutch disks and floating drives.
F-I-T
10-20-2006 16:13:46
Terry:
Sorry I did not see this message until it had slipped down the page.
The clanking sound could be from a delaminated clutch facing, but I doubt it. Generally the clanking sounds come from the metal parts, and that would be things like the outer clamping ring, the floating disks, or even a loose clutch driving disk. If the clutch operates correctly, and feels smooth as you engage it, it's pretty likely that the floating disks are just jingling across the clutch driver gear teeth as everything slides into compression as the clutch pack is squeezed into position and then locked by the over-center toggles and dogs.
If everything seems right and tight, but it is just clanking, it is probably the nature of the beast, but this is just my opinion over the internet without hearing or seeing.
Frank
