730-LP not running right
730-LP
10-19-2006 16:17:26
I have a 730 LP that has lost a lot of power.It was running fine then just loss power it still starts good and sounds fine untill you load it then it falls on its face.I have changed the strainer and the electric shut off and checked the oil in the breather .I would appreciate any comments that you all might have. thanks
430WLPG
10-20-2006 20:20:52
 Re: 730-LP not running right in reply to 730-LP, 10-19-2006 16:17:26
Did it do this after by chance you changed the sparkplugs?They need to be gaped at .015
F-I-T
10-20-2006 06:42:49
Does it run with about the same power on vapor as it does liquid? If so, that would point me towards a restriction in the liquid line form the tank to the converter. Sounds like you're just running out of fuel. When they run short on air it seemed to me I could smell the excess fuel more than normal.
Frank
Glen in TX
10-19-2006 22:26:05
I sure agree with MSD about the air cleaner could be plugged up. You may need to remove the grill, hood and/or air cleaner assembly and give it a good bath. For more extensive LPG trouble shooting & LP systems repair see the I&T JD-16 shop manual for JD 520-730 LPG, gasoline & all-fuel tractors or the JD SM2015 LP Gas Equipment service manual.
MSD
10-19-2006 21:20:20
Check the top of the air cleaner. If you have mud daubers (sp), they will close the entire opening off in time. Bought a 730 LP that did the same thing as yours. The darn things had it about plugged solid.
P Browning
10-19-2006 18:15:56
730-LP -- Go to the JD-H Restoration Site, and then one-click on T-S LP-Gas Tractors. Allow the document to come up and perhaps you will see something that will help. (PatB)
