It Worked F-I-T
Larry Jensen
10-18-2006 18:29:30
The heat lamps did the trick for getting the aluminum piston out. THANKS!! Any suggestions on getting the rings loose without hurting the piston?
F-I-T
10-19-2006 07:06:48
 Re: It Worked F-I-T in reply to Larry Jensen, 10-18-2006 18:29:30
Good deal!
Well, they are likely stuck because the carbon around the rings is swelled with moisture. Breaking the rings is the most reasonable way to remove them, but before that, you might wash the pistons in hot soapy water (no alkyline cleaner!)to remove as much oil as possible, then bake them in the oven at a low setting, like 170* (you can try higher since water boils at 212*, but I think it will evaporate fine at the lower setting), for maybe an hour and let them cool down in the oven. This should drive out the moisture and keeping them in the oven during cool down (like overnight) is similar to keeping something in a desicator, i.e. very low humidity while it comes down to ambient temperature. Then the carbon should be looser, or even fluffy, and the rings should respond to some gentle tapping using a brass drift. Don't hit the surrounding aluminum land edges. When they seem looser, start tapping on one side of the gap, then the other to get them to spread. With a little effort they should break free.
If you're not planning on re-using them, you can probably break the rings by over flexing the gap end and a piece about a quarter of the circumference should come loose, and you can tap it out, then repeat. Keep the old ring fragments so you can match them to your new rings for thickness as that dimension tends to vary with the production of aluminum pistons over the years. You can use one of the sharpest ring fragments held in a Vicegrip to clean the grooves if you don't have access to a ring groove cleaner.
I hope your wife is undersanding. Else you might have to use the heat lamps on the pistons in the garage. In the old days on cast pistons we used to put them in a bucket of hot oil which would boil off the water and replace it with oil. Today I put them in my electrolysis bath, but that will not work with aluminum parts.
Frank
Scott Griffith
10-19-2006 11:59:28
 Re: It Worked F-I-T in reply to F-I-T, 10-19-2006 07:06:48
Hay F-I-T,
Do you ever have to replace the water in your electrolysis bath. I noticed in mine that it worked great for a while and now it seems to work slower, but still works. I know my electrode is needs to be replaced. I have used it to clean all of my parts that will fit in a 55 gallon barrel. Right now it is drawing about 4 amps on a battery box for a 720D.
Scott
F-I-T
10-19-2006 12:21:32
 Re: It Worked F-I-T in reply to Scott Griffith, 10-19-2006 11:59:28
Scott:
I only ever change it if I have to move the tank. You can strain the electrolyte to get the large stuff out, but if the salts are still in the water (they will not deplete through evaporation) but it is getting slow, it is either the ambient temp is falling, or the connections to the electrodes are poor, or the electrodes are covered with red rust or are otherwise depleted. Now if you have had to add a lot of water because you lost some due to exiting with the parts, then you might have to give it a few tablespoons of lye or washing soda to boost it, but check your electrodes first.
