3rd remote for a 4430
farm-b0y
10-18-2006 15:20:29
We bought a 4430 and want to put a loader with grapple on however it only has two remotes. Is it possible to add a 3rd remote? Is there a better way? Thanks
farm-b0y
10-19-2006 08:56:55
 Re: 3rd remote for a 4430 in reply to farm-b0y, 10-18-2006 15:20:29
Thanks a lot for all the help.
MSM
10-19-2006 02:30:46
You can purchase the power beyond block as mentioned below from whole goods at your Deere dealer, along with it you will need hoses from it to the auxillary valve,an auxillary 3 spool valve, and the hoses you have now plumbed to the remotes will have to be shortened to attach to the valve.
Another option is to locate a 3rd remote setup,it is a block that mounts under an existing remote, another select control valve(remote),and all the linkage and lever for the console. They can be found sometimes at salvage yards. With either option you are looking in the $1000 range to do it correctly.
JMS/MN
10-19-2006 16:38:32
 Re: 3rd remote for a 4430 in reply to MSM, 10-19-2006 02:30:46
I've added factory third remotes from Parts Express salvage yards (Worthington Ag) on both 30 and 40 series tractors. Each time was about $700. Ordered new through JD would have been over a grand each time. PE normally goes 50% of new, but not on these setups.
N. TX Tim
10-18-2006 20:35:19
I believe they call the block that mounts behind the remote hookup a "power beyond block." This is what Gerald was referring to...then there is a valve that mounts under the right battery box. I had a 4430 with this setup...was told the whole deal costs about $1000. I had the loader and whole works moved over to my 4450...and it works great.
Tim
Gerald J.
10-18-2006 18:22:45
I believe there is a part from Deere that sets between one of the present valves and the transmission case that has ports for constant pressure and return so you can mount a triple valve on the loader itself and keep the original two valves for running implements while the loader is in place. I've been in the situation where it was necessary to take off the loader for other work and it was worth working out a better scheme so the loader and implement could be used the same hour or minute.
That auxiliary tap is described and shown in the Deere 148/158 loader manuals.
Gerald J.
jddriver
10-18-2006 17:21:17
deere has a three spool valve that mounts under right battery box.Levers come up inti cab and really works slicks
