50 JD GEN paint color
Brian
12-17-1999 09:10:13
Should the generator color be black or green on a JD 50 sn 5000019? Thanks for any help.
Mike Aylward
12-18-1999 06:42:13
 Re: 50 JD GEN paint color in reply to Brian, 12-17-1999 09:10:13
Brian, the generator should be black, but the cast iron pulley should be green. It is my understanding that the generators on the Waterloo tractors were black until a change in assembly line procedures in 1958 when they were then painted green. Hope this helps. Mike
Rob
12-18-1999 18:19:32
 Re: Re: 50 JD GEN paint color in reply to Mike Aylward, 12-18-1999 06:42:13
I have seen a picture of the Waterloo assembly line where they were painting a "50" [before 1958!]. The generator, carburetor, and muffler were on the tractor and painted green. The tractor was pulled thru the line on skeleton steel wheels that were plastered with overspray. Don't get me wrong, I think they look better black. But I've seen otherwise.
OCB
12-17-1999 20:23:24
This is a post I copied from monthes gone by, so you may want to consider the source of the Generator. Or search for more about this date.
In Reply to: Model 50 Generator Color posted by Jason on April 29, 1999 at 16:05:57: Rodney is correct, however a few generators where delivered from deere green.
These few where contracted from a different supplier (not DelcoRamey) and were primed when arriving at Deere.
Deere then painted them Green (instead of Yellow) since this was the paint color they had at their final assembly plants.
The majority were all satin finish Black, painted before arriving at Deere, thus Deere never had to paint them at all.
So... even if you tractor came with a Green gen. I'd sure paint it Black as that was the "intended" collor from Deere.
Ken Talatzko
12-17-1999 20:43:27
 Re: Re: 50 JD GEN paint color in reply to OCB, 12-17-1999 20:23:24
I saw a picture once that was taken at Waterloo on the paint line and everything got a coat of green paint (except the wheels of course). This was done after the tractors were run and dynoed.
Ken.
Rob
12-17-1999 19:28:48
The correct police will get you if you paint it the wrong color! The generators were painted GREEN from the factory. They look better painted BLACK. What YOU think is best is what IS best, it's your tractor. Enjoy!
Ron
12-17-1999 10:10:36
Black
Brian
12-20-1999 07:14:21
 Re: Re: 50 JD GEN paint color in reply to Ron, 12-17-1999 10:10:36
Ok! Black it is! it looks better!
thanks for all the input!
