J/D 40 hydraulic leak
Greg- needs hel
10-18-2006 13:45:53
Hey guys, I need a hand. I've got a 40T which I have had for about a year and tinkering with. The hydraulics never have worked on the tractor but always dripped a bit. I tore the seat off to look for the cause, I found oil spewing out around what looks like a pin with a taper on the end of it. there are 2 pins on the left side of the hydraulic unit. with what looks like a handle attached and a spring. one pin was free and the other stuck. I removed both pins which oil was leaking around cleaned them up and reinstalled. The 3 point hitch goes up and down now, but oil is blowing by the "up pin". also my control levers on the right side don't seem to do anything. is the up and down control on the 3pt hitch controlled by this. both pins look like there pitted a bit, which might be causing oil to blow by? I keep topping the unit up, until it runs out the drain/level cock on the back of the tractor. Is the level too high maybe and blowing out? hopefully someone knows what I'm talking about.... I don't know much about these units. I belive it is a "Touch o matic" system. there is no external hyd. cylinders. These pins have tapered ends on both of them, one is longer then the other..... hopefully someone knows what I'm talking about. thanks alot, Greg.
buckeye al
10-18-2006 14:30:36
 Re: J/D 40 hydraulic leak in reply to Greg- needs help, 10-18-2006 13:45:53
What you seem to describe is a DUAL touchomatic or TOM unit. The "pins" under the seat are pushed in against their respective valve seats (inside) by the cam action of the selector lever under the seat in one mode. When the selector lever is moved the other way, the pins are allowed to push out against the cam by internal hydraulic pressure. They each have but a single "O" ring seal under the bolt on bracket that holds them and the handle in place.
Part of the Dual TOM unit's operation is that there are two arms, one on each of the two rockshafts sticking out the left side of the rockshaft housing. If those two arms are pinned together as usually is the case, the lever under the seat is to be in one position (I think pins in). When pinned together and the selector valve is in this "parallel" mode, the shorter (I think the left but am on thin ice here) operating lever in the quadrant at the right side of the seat is to be in the most rearward or raised position at all times! Deere cautions that damage to the TOM unit can occur if this condition is not observed! Only the longer (I think the right) lever is used to operate the 3 point lift arms in this parallel mode.
When the lift arms are NOT pinned together and the selector valve (under the seat) is in the other mode, lifting capacity of the TOM unit is half that of the parallel mode. The inside lifting arm (on the outer rockshaft on the left side) riases up and down independently of the rear three point hitch and is operated by I think the shorter of the two levers. Without the book or the tractor in front of me, I'm dangerously trusting of my memory but again, I think that's the left lever.
I own a 40W and because mine are always pinned together and the unused handle is wired in the raised position at all times (more powerful parallel mode), I easily forget exactly which is which.
I've totally rebuilt my unit and still I have need of the book from time to time!
It would be wise of you to obtain an operator's manual for the tractor. It gives great instructions on operation of the TOM unit along with a lot of other "good stuff"!
Later.
buickanddeere
10-18-2006 14:21:43
It's all in your oprator's manual. If you don't have the pins in and using the rockshaft independently without out the pocking bolt in the lift arms. Or running with the pins out, the lift arms pinned together and the inside control lever bolted in the rear position. The hydraulics won't work and there is a chance of wrecking the guts of the system. As for the oil leak. Your parts manual shows an upgraded set of seals for the pins. 1-800-522-7448.
