3020 fuel filters
sodly
10-18-2006 12:22:07
third party image
Can someone tell me why there are two, side-by-side, vertical fuel filters (right below the intake manifold) on the (driver's) left side of many 3020 diesels but not all of them? Some appear to have some sort of black box in a green, metal clip there (what is that, anyway?). What's the difference? Were the filters optional? Did they all change over at some point? If so, when did the change occur? Thanks.
msb
10-19-2006 19:53:43
 Re: 3020 fuel filters in reply to sodly, 10-18-2006 12:22:07
The filter with the glass bottom was Standedyne's idea to cut the replacement cost of filters since they only took a cheap paper filter insert.The problem was with the glass bottom didn't always seal well on the large O-ring.There were a lot more got out here locally on the utility tractors that the 3020/4020 models mainly because of economic conditions of the time that didn't let Deere sell a lot of those models in that time frame.I remember of only converting a few tractors in the 3020/4020 models.I converted several of the utility models. Deere quickly came out with a conversion kit due to fire hazard caused by the leaks.
The square Pyrex glass filters used a lot finer filter media than either of the other two older filters and were much easier,cleaner & quicker to change as Bob said.
Bob
10-18-2006 14:30:03
According to JDPARTS, the switch fom the 2 hard-to-change round cartridge filters to the single "box-looking" Roosa-Master filter was made starting with ENGINE serial #280001.
This was sometime AFTER TRACTOR serial #123000.
The exact TRACTOR serial number after the switch was made is NOT given, as far as I can tell.
Third Party Image
Third Party Image
sodly
10-18-2006 14:32:50
 Re: 3020 fuel filters in reply to Bob, 10-18-2006 14:30:03
Thanks for the good info. Is the glass filter easier to change? Looks as if it would be the difficult one.
Bob
10-18-2006 14:58:16
 Re: 3020 fuel filters in reply to sodly, 10-18-2006 14:32:50
The boxy glass (now steel, for safety) filter can be changed in less than a minute, without tools, except for a wrench to loosen the bleeder plug.
You push on the flat retainer spring, release it, and swap the filters, then snap the spring back into place.
sodly
10-18-2006 16:46:29
 Re: 3020 fuel filters in reply to Bob, 10-18-2006 14:58:16
Does the box filter make a mess when you change it? Or does it somehow seal off when you remove it?
Bob
10-18-2006 22:06:30
 Re: 3020 fuel filters in reply to sodly, 10-18-2006 16:46:29
It doesn't seal off when removed. You can either swap it quickly, and put the old filter in a pan to drain, or there is a drain plug on the filter block, allowing you to drain the filter before removal, if desired.
donmyeil
10-18-2006 14:27:55
The 3020 had two spin-on filters all the way thru. The 1969 and newer used 1 glass filter. Deere made a kit to convert to the glass filter which aslo was used on the 10 series as well.
Gerald J.
10-18-2006 12:26:11
I think the double filter was a later option and Deere made a kit to retrofit earlier tractors.
Gerald J.
sodly
10-18-2006 12:32:31
 Re: 3020 fuel filters in reply to Gerald J., 10-18-2006 12:26:11
Hmmm... anyone know for sure? It seems to me that I see more late model 3020s without the filters and more early 3020s with the filters.
Gerald J.
10-18-2006 15:18:31
 Re: 3020 fuel filters in reply to sodly, 10-18-2006 12:32:31
Go by the parts book. Its the true history. I remembered reversed without checking my 4020 parts book which only covers tractors before the transistion to side console. I remember some comments about that in the 70s vintage service bulletins that I have but since my 4020 is gas, diesel details aren't high in remembering priority.
Gerald J.
Glen in TX
10-18-2006 14:31:41
Go take a look at the 3020 parts catalog and others also and you'll see when it happened by serial number and also see the later conversion kit.
