1950 JD B
souNdguy
10-18-2006 11:43:54
I've got a styled 1950 B.. and I've got a question. on the back of the square axle on each side is a pattern of 4 studs, with oversized lugs on them. Implement mounting bolts i guess?
Is this bolt pattern standard or common to any other JD machine? An 'A' for example? I'm assuming only the styled machines.. etc.
Soundguy
johns48b
10-18-2006 19:42:40
 Re: 1950 JD B in reply to souNdguy, 10-18-2006 11:43:54
on my 48 i have the model 200abg cultivator mounted to it and the 212b model planter mounted to the cultivator. the planter is an attachment to the cultivator. the rear cultivator gangs are mounted to the axle in four of those holes and the depth adjustment levers for the cultivators are mounted in two of the other holes, but i think it uses two holes in the front of the axle for the levers now that i think about it. i have a rear step mounted in two of the holes at the back. i don't know if anything else mounted to those holes or not. probably some parts of a mounted corn picker mounted there too.
CLW
10-18-2006 12:18:55
It would be the same.
Mike M
10-18-2006 12:13:48
I think that pattern is close to standard on most all of the 2 cyl. row crops.
