FAN SHAFT BEARINGS
WILYCOAT
10-18-2006 09:43:17
DOES ANYONE HAVE ANY TIPS OR INFO ON HOW TO R&R THE FAN SHAFT BEARINGS ON A 1944 MODEL A I HAVE A SHOP MANUAL BUT IT REALLY DOESN'T GO INTO ANY DETAIL ON HOW TO GO ABOUT REPLACING THIS THE TRACTOR SEEMS TO BE NOISY IN THIS AREA
Glen in TX
10-18-2006 11:18:45
 Re: FAN SHAFT BEARINGS in reply to WILYCOAT, 10-18-2006 09:43:17
The JD service manual Mike speaks of is the SM2004. Just don't get confused and buy a SM2000 yet as it will NOT have what you want right now but does cover electrical and valves. A I&T JD-4 shop manual this site and many other vendors sell may be of some help too. The bearing races will usually slide out easily but if not and are going to replace anyway lay a short weld bead on the race only and let it cool and it should come out.
Mike M
10-18-2006 10:09:19
If you get a copy of the Deere manual made for the late model B tractors it show great detail on this stuff. They are all similar,but they don't make a manual for your exact model.
You will need a small press and a bearing seperator (cheese cutter) My press is just a elchepo harbor freight and has served very well over the years. I put it up on blocks to make it tall enough for these fans and removed the brace out of the center at the bottom and put 2 on the outsides as not to interfer with the length. No sense doing the fan without also doing the governor too ! If you don't have much experience with pressing stuff apart you can do more damage than good. And if so be prepared to pay for an education or pay someone to do it. Just remembered ? I think Roberts carb. repair sells a viedo on this. www.robertscarbrepair.com It should be a good investment.
