720 transmission stuck in 4th and 6th gear
Darin IN
10-18-2006 09:15:08
I'm trying to help a neighbor get his grandpas 720 gas mobile again. It seems to be stuck in 4th and 6th gear at the same time. The shifter can be moved to both sides of the quadrant okay. It slides into most of the other gears easily, but won't go into 4th or 6th. From what I have read on this forum, I need to take off the top cover shifter casting. I did this on my B several years ago, but I have some questions about the 720. Do I have to take the hood off or can I just unbolt the upper cast dash from the shifter casting and slide the shifter casting out up and rearward? If I have to take the hood off, is the gas tank bolted to the hood, like on the B? What's the best guess as to what's wrong? There was no noise before this happened. Any help would be appreciated.
GPULLER
10-18-2006 10:38:22
 Re: 720 transmission stuck in 4th and 6th gear in reply to Darin IN, 10-18-2006 09:15:08
I have done this to my 720D. I have found that it's easier to remove the hood. The fuel tank is not bolted to the hood. Trying to line up the shifter and forks with the dash and hood in the way can be a pain.
Mike M
10-18-2006 09:36:53
It's more than likely just worn out. Sometimes those shifter forks and their pawls and pawl interlocks can wear some letting it move when it isn't to.Also make sure the shift lever isn't coming apart and moving all over the place. Once you get the top off you can play around with it and see what gear it may be stuck in and if any of the forks move without the interlock first being moved.
To get the top off I wonder if you can just remove the 2 bolts that hold the cast dash to the shift quadrant then lift the dash and hood and everything up enough and tie it up with a rope to the rafters and then gain enough room to pull the shifter assy. off. I think I did this on a gas 720 or 730 ? once before. I had to replace or rebuild the interlock pin for the over/underdrive shifter on some of them.
