Carburator Problems, Model B John Deere
ol' guy
10-17-2006 18:31:13
After struggling with difficult starting of my '41 hand-start "B", a friend suggested switching the carbs between the '41 and a '51 (gas). The hand-start tractor immediately started much easier; in fact, it could not start much better. The '51 starts alright, but not as good as it did originally with the other carb, but it doesn't run as good as before, and doesn't respond to adjusting the idle and load needles as it should. This carb was worked on by 2 recognized 2-cyl. carb "experts".
My question is-- What is the correct DLT carb number for the late (1951) gas B?? I'm thninking of trying to buy one, and I want it to be correct. I want to leave the carb that's now on the '41 since it starts and runs to well. Your help, as always is appreciated.
dan hill
10-25-2006 03:22:14
 Re: Carburator Problems, Model B John Deere in reply to ol' guy, 10-17-2006 18:31:13
I have found plenty of dirt in the idle passages of these carbs,usually a light fluffy material.Surging idle is a tipoff.
Kurt_JDB
10-17-2006 19:19:07
"ol Guy,
The carb you want is a DLTX-67
Kurt
P Browning
10-17-2006 18:36:55
ol' guy -- go to the JD-H restoration site (below) and when you arrive, one-click on CARB ID CHART which has all the lettered series two-cylinder tractors listed along with the carburetors originally installed on them. (PatB)
